System Halted su AGPF OpenWrt
  • 1 Risposte
  • 3603 Visite
Offline frankiep87
  • 19
« il: 28 Giugno 2012, 13:04 »
Ho flashato questa immagine openwrt-AGV2+W-jffs2-128k-cfe.bin (presa da http://downloads.openwrt.org/snapshots/trunk/brcm63xx/) attraverso la seriale, il flash si conclude bene ma quando avvio la board ottengo questo errore e il sistema non si avvia:
CFE version 1.0.37-8.7 for AGPF 0007 BCM96358 (32bit,SP,BE)
Build Date: lun giu 16 10:47:46 CEST 2008 ( gpaolo@buildserver )
Copyright (C) 2000-2005 Broadcom Corporation.
Boot Address 0xbe000000
Initializing Arena.
Initializing Devices.
Flash info:
device_id : ............227E
meminfo.nsect:..........128
totalSize:..............1000000
num_erase_blocks:...... 1
device_size:............1000000
Parallel flash device: name MX29L128DT, id 0x227e, size 16384KB
CPU type 0x2A010: 300MHz, Bus: 133MHz, Ref: 64MHz
CPU running TP0
Total memory: 33554432 bytes (32MB)
Total memory used by CFE:  0x80401000 - 0x80528CB0 (1211568)
Initialized Data:          0x8041E8A0 - 0x804204C0 (7200)
BSS Area:                  0x804204C0 - 0x80426CB0 (26608)
Local Heap:                0x80426CB0 - 0x80526CB0 (1048576)
Stack Area:                0x80526CB0 - 0x80528CB0 (8192)
Text (code) segment:       0x80401000 - 0x8041E894 (120980)
Boot area (physical):      0x00529000 - 0x00569000
Relocation Factor:         I:00000000 - D:00000000
Board IP address                  : 192.168.1.1:ffffff00
Host IP address                   : 192.168.1.100
Gateway IP address                :
Run from flash/host (f/h)         : f
Default host run file name        : vmlinux
Default host flash file name      : openrg.img
Boot delay (0-9 seconds)          : 1
Board Id (0-3)                    : AGPF-S0
Number of MAC Addresses (1-32)    : 13
Base MAC Address                  : 02:10:18:01:01:01
PSI Size (1-64) KBytes            : 24
Main Thread Number [0|1]          : 0
*** Press any key to stop auto run (1 seconds) ***
Auto run second count down: 0
Sizeof Tag Used : 256
One only valid image tag found ...
Trying to boot from FIRST image copy (0x80010000) ...
latest imageSequence found: ... 0
- Flash Kernel Address: 0xBE020100
- Tag->kernelLen: 0x0011FF00
- Tag Kernel crc : 0xC66F7702 - calculated: 0xC66F7702
Decompression OK! - starting 0
Entry at 0x80010000
Distribution:
Version:
Build Date: Cjffs2-128k
Closing network.
Starting program at 0x80010000
SGP START PARTITION: 0
[    0.000000] Linux version 3.3.8 (openwrt@builder) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Wed Jun 27 16:27:39 MDT 2012
[    0.000000] Detected Broadcom 0x6358 CPU revision a1
[    0.000000] CPU frequency is 300 MHz
[    0.000000] 32MB of RAM installed
[    0.000000] registering 40 GPIOs
[    0.000000] gpiochip_add: registered GPIOs 0 to 39 on device: bcm63xx-gpio
[    0.000000] board_bcm963xx: Boot address 0xbe000000
[    0.000000] board_bcm963xx: CFE version: unknown
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU revision is: 0002a010 (Broadcom BMIPS4350)
[    0.000000] board_bcm963xx: board name: AGPF-S0
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 02000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone PFN ranges:
[    0.000000]   Normal   0x00000000 -> 0x00002000
[    0.000000] Movable zone start PFN for each node
[    0.000000] Early memory PFN ranges
[    0.000000]     0: 0x00000000 -> 0x00002000
[    0.000000] Reserving 0MB of memory at 0MB for crashkernel
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
[    0.000000] Kernel command line:  root=/dev/mtdblock2 rootfstype=squashfs,jffs2 noinitrd console=ttyS0,115200
[    0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[    0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Primary instruction cache 32kB, VIPT, 2-way, linesize 16 bytes.
[    0.000000] Primary data cache 16kB, 2-way, VIPT, cache aliases, linesize 16 bytes
[    0.000000] Memory: 29020k/32768k available (2347k kernel code, 3748k reserved, 656k data, 200k init, 0k highmem)
[    0.000000] NR_IRQS:128
[    0.000000] Calibrating delay loop... 299.26 BogoMIPS (lpj=598528)
[    0.036000] pid_max: default: 32768 minimum: 301
[    0.040000] Mount-cache hash table entries: 512
[    0.048000] NET: Registered protocol family 16
[    0.060000] registering PCI controller with io_map_base unset
[    0.064000] registering PCI controller with io_map_base unset
[    0.076000] bio: create slab <bio-0> at 0
[    0.084000] PCI host bridge to bus 0000:00
[    0.088000] pci_bus 0000:00: root bus resource [mem 0x30000000-0x37ffffff]
[    0.092000] pci_bus 0000:00: root bus resource [io  0x8000000-0x8007fff]
[    0.108000] pci 0000:00:01.0: BAR 0: assigned [mem 0x30000000-0x30001fff]
[    0.112000] PCI host bridge to bus 0000:01
[    0.116000] pci_bus 0000:01: root bus resource [mem 0x38000000-0x3fffffff]
[    0.120000] pci_bus 0000:01: root bus resource [io  0x8008000-0x800ffff]
[    0.124000] pci 0000:01:1e.0: CardBus bridge to [bus 02-05]
[    0.128000] pci 0000:01:1e.0:   bridge window [io  0x0001-0x0000]
[    0.132000] pci 0000:01:1e.0:   bridge window [io  0x0001-0x0000]
[    0.136000] pci 0000:01:1e.0:   bridge window [mem 0x00000001-0x00000000]
[    0.140000] PCI: Enabling device 0000:01:1e.0 (0000 -> 0003)
[    0.144000] Switching to clocksource MIPS
[    0.156000] PCI: Enabling device 0000:00:01.0 (0000 -> 0002)
[    0.184000] ssb: Found chip with id 0x4318, rev 0x02 and package 0x02
[    0.236000] ssb: Sonics Silicon Backplane found on PCI device 0000:00:01.0
[    0.244000] NET: Registered protocol family 2
[    0.248000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.256000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[    0.264000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.272000] TCP: Hash tables configured (established 1024 bind 1024)
[    0.280000] TCP reno registered
[    0.280000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.288000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.296000] NET: Registered protocol family 1
[    0.304000] audit: initializing netlink socket (disabled)
[    0.308000] type=2000 audit(0.308:1): initialized
[    0.316000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.320000] JFFlS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.332000] msgmni has been set to 56
[    0.336000] io scheduler noop registered
[    0.340000] io scheduler deadline registered (default)
[    0.348000] bcm63xx_uart.0: ttyS0 at MMIO 0xfffe0100 (irq = 10) is a bcm63xx_uart
[    0.356000] console [ttyS0] enabled, bootconsole disabled
[    0.372000] physmap platform flash device: 02000000 at 1e000000
[    0.380000] physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002101
[    0.388000] Amd/Fujitsu Extended Query Table at 0x0040
[    0.396000]   Amd/Fujitsu Extended Query version 1.3.
[    0.400000] number of CFI chips: 1
[    0.404000] bcm63xxpart: CFE boot tag found with version 8 and board type AGPF-S0
[    0.412000] bcm63xxpart: Partition 0 is CFE offset 0 and length 20000
[    0.420000] bcm63xxpart: Partition 1 is kernel offset 20100 and length 11ff00
[    0.424000] bcm63xxpart: Partition 2 is rootfs offset 140000 and length ea0000
[    0.432000] bcm63xxpart: Partition 3 is nvram offset fe0000 and length 20000
[    0.440000] bcm63xxpart: Partition 4 is linux offset 20000 and length fc0000
[    0.448000] bcm63xxpart: Spare partition is offset 380004 and length c5fffc
[    0.456000] 5 bcm63xxpart partitions found on MTD device physmap-flash.0
[    0.460000] Creating 5 MTD partitions on "physmap-flash.0":
[    0.468000] 0x000000000000-0x000000020000 : "CFE"
[    0.476000] 0x000000020100-0x000000140000 : "kernel"
[    0.480000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[    0.496000] 0x000000140000-0x000000fe0000 : "rootfs"
[    0.508000] mtd: partition "rootfs" set to be root filesystem
[    0.512000] split_squashfs: no squashfs found in "physmap-flash.0"
[    0.520000] 0x000000fe0000-0x000001000000 : "nvram"
[    0.528000] 0x000000020000-0x000000fe0000 : "linux"
[    0.544000] bcm63xx_enet MII bus: probed
[    0.548000] bcm63xx_enet bcm63xx_enet.0: attached PHY at address 1 [Broadcom BCM63XX (2)]
[    0.564000] bcm63xx-wdt bcm63xx-wdt:  started, timer margin: 30 sec
[    0.580000] TCP westwood registered
[    0.584000] NET: Registered protocol family 17
[    0.588000] Bridge firewalling registered
[    0.596000] 8021q: 802.1Q VLAN Support v1.8
[    1.120000] jffs2_scan_eraseblock(): End of filesystem marker found at 0x220000
[    1.128000] jffs2_build_filesystem(): unlocking the mtd device... done.
[    1.132000] jffs2_build_filesystem(): erasing all blocks after the end marker... done.
[   40.960000] JFFS2 notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   40.976000] VFS: Mounted root (jffs2 filesystem) readonly on device 31:2.
[   40.984000] Freeing unused kernel memory: 200k freed
awk: /proc/cpuinfo: No such file or directory
[   43.132000] eth1: link forced UP - 100/full - flow control off/off
[   43.376000] roboswitch: Probing device eth0: Failed to enable switch
[   43.384000] roboswitch: Probing device eth1: found a 5325! It's a 5350.
- preinit -
Press the [f] key and hit [enter] to enter failsafe mode
- regular preinit -
- init -
Please press Enter to activate this console. [   50.116000] Compat-wireless backport release: compat-wireless-2012-06-14
[   50.124000] Backport based on wireless-testing.git master-2012-06-14
[   50.128000] compat.git: wireless-testing.git
[   50.328000] cfg80211: Calling CRDA to update world regulatory domain
[   50.332000] cfg80211: World regulatory domain updated:
[   50.340000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   50.348000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   50.356000] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   50.364000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   50.372000] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   50.380000] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 20[   51.228000] b43-phy0: Broadcom 4318 WLAN found (core revision 9)
[   51.316000] Broadcom 43xx driver loaded [ Features: PNL ]
[   51.368000] Button Hotplug driver version 0.4.1
[   51.528000] PPP generic driver version 2.4.2
[   51.728000] ip_tables: (C) 2000-2006 Netfilter Core Team
[   51.964000] NET: Registered protocol family 24
[   52.040000] nf_conntrack version 0.5.0 (456 buckets, 1824 max)
[   52.448000] input: gpio-keys-polled as /devices/platform/gpio-keys-polled.0/input/input0
[   54.940000] System halted.
cosa può essere??? riesco ad accedere alla shell solo in failsafe mode premendo F quando dice "Press the [f] key and hit [enter] to enter failsafe mode"
Grazie in anticipo!
Offline dariowolf
  • 144
Re:System Halted su AGPF OpenWrt
« Risposta #1 il: 13 Luglio 2012, 16:48 »
