downgrade stb pirelli hy101 un aiutino.
  • 0 Risposte
  • 6127 Visite
Offline gabry751
  • 18
« il: 15 Febbraio 2011, 16:47 »
ho seguito questa guida x downgrade
Guida creata da litio
Guida per UBUNTU 9.10 (debian)
- Disabilitare Applet NetworkManager (gestore delle periferiche di rete vicino l'orologio sulla barra superiore per gnome) attraverso tasto destro del mouse e spuntando "ABILITA RETE"
- configurare un indirizzo fisso al PC cioè aprite il terminale e date il comando "sudo ifconfig eth0 83.221.117.229 netmask 255.255.255.0"
- installate dhcp3-server tramite il comando "sudo apt-get install dhcp3-server"
- scaricare dhcpd.conf (qui di seguito) , copiarlo in /etc/dhcp3/
#dhcpd.conf
# required to get dhcpd started
ddns-update-style none;
ddns-updates off;
authoritative;
#allow bootp;
local-address 83.221.117.229;
option domain-name-servers 83.221.117.229;
option time-servers 83.221.117.229;
option ntp-servers 83.221.117.229;
option domain-name "pirelli.stb";
default-lease-time 3600; # 7200 = 2 hours
max-lease-time 3600; # 14400 = 4 hours 86400 = 1 day
option vendor-encapsulated-options code 43 = string;
option pirelli-download-method code 160 = string;
option pirelli-tftp-server code 161 = string;
option pirelli-tftp-image code 162 = string;
option pirelli-multicast-address code 163 = string;
class "pirelli-stb" {
match if (option vendor-class-identifier = "pirelli-stb");
subnet 83.221.117.0 netmask 255.255.255.0 {
option subnet-mask 255.255.255.0;
option routers 83.221.117.229;
option broadcast-address 83.221.117.255;
pool {
allow members of "pirelli-stb";
range 83.221.117.230 83.221.117.234;
class "pirelli-stb-mboot" {
match if ((option vendor-encapsulated-options = "mboot") and (option vendor-class-identifier = "pirelli-stb"));
option pirelli-download-method 1;
option pirelli-tftp-server 53:DD:75:E5 ; # 83.221.117.229
option pirelli-tftp-image "recovery";
class "pirelli-stb-upgrd" {
match if ((option vendor-encapsulated-options = "upgrd") and (option vendor-class-identifier = "pirelli-stb"));
option vendor-encapsulated-options 1:4:E1:0:0:5:2:2:4:57; # 225.0.0.5:1111
- (ri)lanciare il server DHCP con il comando "sudo /etc/init.d/dhcp3-server restart"
- scaricare mserver.tgz.Debian QUI e scompattarlo (ad esempio in /usr/local/ dove quindi troverete (dopo aver scompattato) la cartella mserver_Debian
- scaricare mserver.xml (qui di seguito) nella cartella /usr/local/mserver_Debian/mserver_xml/
<?xml version ="1.0"?>
<!DOCTYPE mserverconfig SYSTEM "mserverconfig.dtd">
<mserverconfig>
<server>
<speed>100</speed>
<ttl>2</ttl>
</server>
<streams>
<file>
<name>telecomstb-1.8.1-0001-PROD-Rel.tar.gz._SIGNED</name>
<ip>225.0.0.6</ip>
<port>1111</port>
<blocksize>1428</blocksize>
<type>FILE</type>
<repeatheader>1000</repeatheader>
<bitrate>2000</bitrate>
<interface>eth0</interface>
<version>1</version>
<major>8</major>
<minor>1</minor>
</file>
<file>
<ip>225.0.0.5</ip>
<port>1111</port>
<type>FILE</type>
<major>8</major>
<minor>1</minor>
</file>
</streams>
</mserverconfig>
- installare tftpd-hpa con il comando "sudo apt-get install tftpd-hpa"
- scaricare l'immagine di recovery da http://www.megaupload.com/?d=NXAGL016 e metterla sotto la cartella /var/lib/tftpboot
- editare il file "tftpd-hpa" con il comando sudo gedit /etc/default/tftpd-hpa modificando la riga che contiene la parola RUN_DAEMON (dovrebbe essere la terza RIGA) nel seguente modo RUN_DAEMON="yes"
- scaricare i firmware del decoder (versione 1.8.1) da QUI e metterli nella directory /usr/local/mserver_Debian/mserver_xml/
- verificare che il file mserver.xml punti al file di firmware di vostro interesse e verificate che il numero di versione sia uguale a quello del firmware in caso di upgrade e recovery, maggiore in caso di downgrade
- spostatevi nella directory /usr/local/mserver_Debian/mserver_xml/ e lanciare "sudo ./mserver", che eroghera' in multicast il firmware prescelto (corretto errore segnalato)
- lanciare wireshark su eth0 (opzionale, ma ALTAMENTE consigliato) con il comando "sudo wireshark" se non lo avete installato digitate "sudo apt-get install wireshark wireshark-common"
- collegare il Decoder di alice al PC con cavo di rete e accendere il decoder
- dall'output di wireshark (precisamente scorrendo fra le varie righe di output e leggendo in basso fra tutti quei numeri e le scritte strane) ci possiamo rendere conto se ci troviamo in fase di:
UPGRADE: il STB ha un firmware buono, prende l'indirizzo IP in modalita' "upgrd" e fa una join al gruppo multicast 225.0.0.5:1111, erogato dall'mserver, scarica il firmware, lo scrive in flash e fa reboot. Se nei campi appositi del file mserver.xml avete messo la versione effettiva del fimware caricato, al reboot successivo il STB non fara' piu' l'upgrade.
DOWNGRADE: il STB ha un firmware buono, prende l'indirizzo IP in modalita' "upgrd" e fa una join al gruppo multicast 225.0.0.5:1111, erogato dall'mserver, scarica il firmware, lo scrive in flash e fa reboot. Per forzare il downgrade, nei campi appositi del file mserver.xml e' stato messo un numero di versione SUPERIORE al fimware caricato, per cui al reboot successivo bisogna spegnere l'mserver (o il DHCP server), per evitare che il STB faccia nuovamente il downgrade, all'infinito.
RECOVERY: il STB ha un firmware corrotto, prende l'indirizzo IP in modalita' "mboot" e scarica via TFTP il file "recovery", fa reboot, riprende l'indirizzo IP in modalita' "upgrd", fa una join al gruppo multicast 225.0.0.5:1111, erogato dall'mserver, scarica il firmware, lo scrive in flash e fa reboot. Se nei campi appositi del file mserver.xml avete messo la versione effettiva del fimware caricato, al reboot successivo il STB non fara' piu' l'upgrade.
il problema è  che dando il comando cd /usr/local/mserver_Debian/mserver_xml mi da risposta
gabri@gabri-desktop:/usr/local/mserver_Debian/mserver_xml$ lo faccio partire con sudo ./mserver e la risposta è :
telsey multicast server (v.1.5). xml configurazion version.
parse error at line 1:
xml or text declaration not at start of entity.
 non so proprio venirne a capo, x favore mi date  un suggerimento?
« Ultima modifica: 15 Febbraio 2011, 16:53 da gabry751 »
