Hardware e Software => Connessioni ADSL/VDSL/FTTC => Topic aperto da: xShoalKing - 15 Agosto 2020, 15:28
Buonasera ragazzi, esiste, che voi sappiate, un modo per effettuare il debranding del MF286R in modo da farlo diventare MF286 e flashare il firmware B08 per ottenere il blocco bande? Mi son rotto di switchare a ca**o da LTE 5 tacche a 40+mbps a LTE+ 1 tacca 13mbps senza motivo...
purtroppo questi comandi vanno sulo su MF286 FW B06
curl -s -H "Referer: http://192.168.0.1/index.html" "http://192.168.0.1/goform/goform_set_cmd_process?isTest=false&goformId=SET_NETWORK_BAND_LOCK<e_band_lock=0x8080045"
curl -s -H "Referer: http://192.168.0.1/index.html" "http://192.168.0.1/goform/goform_set_cmd_process?isTest=false&goformId=SET_NETWORK_BAND_LOCK<e_band_lock=0x04"
curl -s -H "Referer: http://192.168.0.1/index.html" "http://192.168.0.1/goform/goform_set_cmd_process?isTest=false&goformId=SET_NETWORK_BAND_LOCK<e_band_lock=0x40"
curl -s -H "Referer: http://192.168.0.1/index.html" "http://192.168.0.1/goform/goform_set_cmd_process?isTest=false&goformId=SET_NETWORK_BAND_LOCK<e_band_lock=0x80000"
curl -s -H "Referer: http://192.168.0.1/index.html" "http://192.168.0.1/goform/goform_set_cmd_process?isTest=false&goformId=SET_NETWORK_BAND_LOCK<e_band_lock=0x8000000"
curl -s -H "Referer: http://192.168.0.1/index.html" "http://192.168.0.1/goform/goform_set_cmd_process?isTest=false&goformId=SET_NETWORK_BAND_LOCK<e_band_lock=0x45"
curl -s -H "Referer: http://192.168.0.1/index.html" "http://192.168.0.1/goform/goform_set_cmd_process?isTest=false&goformId=SET_NETWORK_BAND_LOCK<e_band_lock=0x80040"
curl -s -H "Referer: http://192.168.0.1/index.html" "http://192.168.0.1/goform/goform_set_cmd_process?isTest=false&goformId=SET_NETWORK_BAND_LOCK<e_band_lock=0x80004"
curl -s -H "Referer: http://192.168.0.1/index.html" "http://192.168.0.1/goform/goform_set_cmd_process?isTest=false&goformId=SET_NETWORK_BAND_LOCK<e_band_lock=0x8080000"
salve, qua ce tutta la procedura piu i link per tutto il materiale....
https://forum.fibra.click/d/9519-debrand-e-sblocco-bande-su-zte-mf286r
