Hardware e Software => Connessioni ADSL/VDSL/FTTC => Topic aperto da: d2mac - 11 Marzo 2016, 19:54
ciao
avevo recuperato il router WhiteBox WDR3600 ,modificato e instalato un firmware gargoile (1.7.1 ) e andato bene per parecchi mesi ,ma dopo mi sono ritrovato il router che andava sempre in reboot continuo.
o provato le diverse procedure per il recupero ,anche con seriale , ma non o risolto nulla continua il reboot metto delle immagini riuscite a fare metre mandavo il recovery con tftp e con putty in ascolto su seriale
(http://i.imgur.com/B11S98j.png)
(http://i.imgur.com/ve5ICCV.png)
e questo e quello che leggo con putty
U-Boot 1.1.4 (Oct 21 2014 - 12:49:00)
U-boot DB120
DRAM: 128 MB
id read 0x100000ff
flash size 8MB, sector count = 128
Flash: 8 MB
Using default environment
PCIe Reset OK!!!!!!
In: serial
Out: serial
Err: serial
Net: ag934x_enet_initialize...
No valid address in Flash. Using fixed address
wasp reset mask:c03300
WASP ----> S17 PHY *
: cfg1 0x7 cfg2 0x7114
eth0: ba:be:fa:ce:08:41
athrs17_reg_init: complete
eth0 up
eth0
dup 1 speed 1000
Using eth0 device
TFTP from server 192.168.0.66; our IP address is 192.168.0.86
Filename 'wdr3600v1_tp_recovery.bin'.
Load address: 0x80060000
Loading: #################################################################
done
Bytes transferred = 8126464 (7c0000 hex)
original_product_id = 36000001
original_product_ver = 01
recovery_product_id = 36000001
recovery_product_ver = 01
auto update firmware: product id verify sucess!
Firmware recovery: product id verify sucess!
Firmware recovery: filesize = 0x7c0000.
U-boot DB120
DRAM: 128 MB
id read 0x100000ff
Flash: 8 MB
PCIe Reset OK!!!!!!
In: serial
Out: serial
Err: serial
eth0 up
eth0
Autobooting in 1 seconds
## Booting image at 9f020000 ...
Uncompressing Kernel Image ... OK
Starting kernel ...
[ 0.000000] Linux version 3.10.49 (eric@Osiris) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 unknown) ) #3 Fri Feb 27 17:16:22 EST 2015
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 0001974c (MIPS 74Kc)
[ 0.000000] SoC: Atheros AR9344 rev 2
[ 0.000000] Clocks: CPU:560.000MHz, DDR:450.000MHz, AHB:225.000MHz, Ref:40.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x07ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x07ffffff]
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: board=TL-WDR4300 console=ttyS0,115200 rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 126184k/131072k available (2287k kernel code, 4888k reserved, 613k data, 232k init, 0k highmem)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop... 278.93 BogoMIPS (lpj=1394688)
[ 0.070000] pid_max: default: 32768 minimum: 301
[ 0.070000] Mount-cache hash table entries: 512
[ 0.080000] NET: Registered protocol family 16
[ 0.080000] MIPS: machine is TP-LINK TL-WDR3600/4300/4310
[ 0.090000] registering PCI controller with io_map_base unset
[ 0.310000] bio: create slab <bio-0> at 0
[ 0.310000] PCI host bridge to bus 0000:00
[ 0.320000] pci_bus 0000:00: root bus resource [mem 0x10000000-0x13ffffff]
[ 0.320000] pci_bus 0000:00: root bus resource [io 0x0000]
[ 0.330000] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 0.330000] pci 0000:00:00.0: invalid calibration data
[ 0.340000] pci 0000:00:00.0: BAR 0: assigned [mem 0x10000000-0x1001ffff 64bit]
[ 0.340000] pci 0000:00:00.0: BAR 6: assigned [mem 0x10020000-0x1002ffff pref]
[ 0.350000] pci 0000:00:00.0: using irq 40 for pin 1
[ 0.350000] Switching to clocksource MIPS
[ 0.360000] NET: Registered protocol family 2
[ 0.360000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.360000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.370000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.370000] TCP: reno registered
[ 0.370000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.380000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.390000] NET: Registered protocol family 1
[ 0.400000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.410000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.420000] msgmni has been set to 246
[ 0.430000] io scheduler noop registered
[ 0.430000] io scheduler deadline registered (default)
[ 0.430000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
+▒r▒▒▒▒▒▒▒serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
[ 0.470000] console [ttyS0] enabled, bootconsole disabled
[ 0.480000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[ 0.490000] m25p80 spi0.0: found s25fl064k, expected m25p80
[ 0.490000] m25p80 spi0.0: s25fl064k (8192 Kbytes)
[ 0.500000] 5 tp-link partitions found on MTD device spi0.0
[ 0.510000] Creating 5 MTD partitions on "spi0.0":
[ 0.510000] 0x000000000000-0x000000020000 : "u-boot"
[ 0.520000] 0x000000020000-0x0000001271fc : "kernel"
[ 0.520000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[ 0.540000] 0x0000001271fc-0x0000007f0000 : "rootfs"
[ 0.540000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[ 0.560000] mtd: device 2 (rootfs) set to be root filesystem
[ 0.560000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.570000] 0x0000006e0000-0x0000007f0000 : "rootfs_data"
[ 0.570000] 0x0000007f0000-0x000000800000 : "art"
[ 0.580000] 0x000000020000-0x0000007f0000 : "firmware"
[ 0.620000] switch0: Atheros AR8327 rev. 4 switch registered on ag71xx-mdio.0
[ 1.840000] libphy: ag71xx_mdio: probed
[ 2.390000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.0:00 [uid=004dd034, driver=Atheros AR8216/AR8236/AR8316]
[ 2.400000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:RGMII
[ 2.410000] TCP: cubic registered
[ 2.410000] NET: Registered protocol family 17
[ 2.420000] Bridge firewalling registered
[ 2.420000] Ebtables v2.0 registered
[ 2.430000] 8021q: 802.1Q VLAN Support v1.8
[ 2.440000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[ 2.450000] Freeing unused kernel memory: 232K (80336000 - 80370000)
procd: Console is alive
procd: - watchdog -
[ 5.780000] usbcore: registered new interface driver usbfs
[ 5.780000] usbcore: registered new interface driver hub
[ 5.790000] usbcore: registered new device driver usb
[ 5.830000] SCSI subsystem initialized
[ 5.840000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.850000] ehci-platform: EHCI generic platform driver
[ 5.850000] ehci-platform ehci-platform: EHCI Host Controller
[ 5.860000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 5.870000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 5.890000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 5.890000] hub 1-0:1.0: USB hub found
[ 5.900000] hub 1-0:1.0: 1 port detected
[ 5.900000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 5.910000] usbcore: registered new interface driver usb-storage
procd: - preinit -
[ 6.310000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 6.490000] hub 1-1:1.0: USB hub found
[ 6.490000] hub 1-1:1.0: 4 ports detected
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 8.420000] eth0: link up (1000Mbps/Full duplex)
kmod: ran 1 iterations
[ 10.080000] jffs2: notice: (379) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 28 of xref (0 dead, 0 orphan) found.
block: extroot: no root or overlay mount defined
jffs2 is ready
jffs2 is ready
[ 10.150000] jffs2: notice: (376) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 28 of xref (0 dead, 0 orphan) found.
switching to overlay
[ 10.190000] eth0: link down
procd: - early -
procd: - watchdog -
Failed to connect to ubus
procd: - ubus -
procd: - init -
Please press Enter to activate this console.
[ 12.740000] RPC: Registered named UNIX socket transport module.
[ 12.750000] RPC: Registered udp transport module.
[ 12.750000] RPC: Registered tcp transport module.
[ 12.760000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 12.790000] tun: Universal TUN/TAP device driver, 1.6
[ 12.790000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 12.800000] gre: GRE over IPv4 demultiplexor driver
[ 12.810000] ip_gre: GRE over IPv4 tunneling driver
[ 12.850000] Installing knfsd (copyright (C) 1996 [email protected]).
[ 12.880000] Hooked IMQ after mangle on PREROUTING
[ 12.880000] Hooked IMQ after nat on POSTROUTING
[ 12.890000] IMQ driver loaded successfully. (numdevs = 2, numqueues = 1)
[ 12.890000] Hooking IMQ before NAT on PREROUTING.
[ 12.900000] Hooking IMQ after NAT on POSTROUTING.
[ 12.910000] Netfilter messages via NETLINK v0.30.
[ 12.920000] ip_set: protocol 6
[ 12.960000] u32 classifier
[ 12.960000] input device check on
[ 12.970000] Actions configured
[ 12.980000] Mirror/redirect action on
[ 13.000000] Failed to load ipt action
[ 13.020000] fuse init (API version 7.22)
[ 13.030000] usbcore: registered new interface driver cdc_acm
[ 13.040000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 13.060000] usbcore: registered new interface driver cdc_wdm
[ 13.070000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[ 13.070000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 13.090000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 13.110000] nf_conntrack version 0.5.0 (1975 buckets, 7900 max)
[ 13.160000] usbcore: registered new interface driver ums-alauda
[ 13.170000] usbcore: registered new interface driver ums-cypress
[ 13.190000] usbcore: registered new interface driver ums-datafab
[ 13.200000] usbcore: registered new interface driver ums-freecom
[ 13.210000] usbcore: registered new interface driver ums-isd200
[ 13.220000] usbcore: registered new interface driver ums-jumpshot
[ 13.230000] usbcore: registered new interface driver ums-karma
[ 13.260000] usbcore: registered new interface driver ums-sddr09
[ 13.290000] usbcore: registered new interface driver ums-sddr55
[ 13.290000] usbcore: registered new interface driver ums-usbat
[ 13.310000] usbcore: registered new interface driver usblp
[ 13.360000] usbcore: registered new interface driver usbserial
[ 13.360000] usbcore: registered new interface driver usbserial_generic
[ 13.380000] usbserial: USB Serial support registered for generic
[ 13.450000] xt_time: kernel timezone is -0000
[ 13.530000] cfg80211: Calling CRDA to update world regulatory domain
[ 13.550000] cfg80211: World regulatory domain updated:
[ 13.550000] cfg80211: DFS Master region: unset
[ 13.550000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 13.560000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.570000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.580000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.590000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.600000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 13.610000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 13.610000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.620000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 13.670000] PPP generic driver version 2.4.2
[ 13.690000] PPP MPPE Compression module registered
[ 13.690000] NET: Registered protocol family 24
[ 13.710000] PPTP driver version 0.8.5
[ 13.710000] usbcore: registered new interface driver qmi_wwan
[ 13.730000] usbcore: registered new interface driver sierra
[ 13.740000] usbserial: USB Serial support registered for Sierra USB modem
[ 13.920000] usbcore: registered new interface driver option
[ 13.930000] usbserial: USB Serial support registered for GSM modem (1-port)
[ 13.950000] usbcore: registered new interface driver qcserial
[ 13.950000] usbserial: USB Serial support registered for Qualcomm USB modem
[ 14.110000] cfg80211: Calling CRDA for country: US
[ 14.120000] ieee80211 phy0: Atheros AR9340 Rev:0 mem=0xb8100000, irq=47
[ 14.120000] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
[ 14.150000] cfg80211: Regulatory domain changed to country: US
[ 14.150000] cfg80211: DFS Master region: FCC
[ 14.160000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 14.170000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 14.170000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[ 14.180000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[ 14.190000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 14.200000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 14.250000] ieee80211 phy1: Atheros AR9300 Rev:4 mem=0xb0000000, irq=40
[ 25.490000] device eth0.1 entered promiscuous mode
[ 25.490000] device eth0 entered promiscuous mode
[ 25.520000] device eth0.2 entered promiscuous mode
[ 27.110000] eth0: link up (1000Mbps/Full duplex)
[ 27.110000] br-lan: port 1(eth0.1) entered forwarding state
[ 27.120000] br-lan: port 1(eth0.1) entered forwarding state
[ 27.120000] br-lan: port 2(eth0.2) entered forwarding state
[ 27.130000] br-lan: port 2(eth0.2) entered forwarding state
[ 29.120000] br-lan: port 1(eth0.1) entered forwarding state
[ 29.130000] br-lan: port 2(eth0.2) entered forwarding state
procd: - init complete -
[ 58.670000] ipt_bandwidth: timezone shift of 120 minutes detected, adjusting
[ 58.680000] old minutes west=0, new minutes west=-120
[ 69.650000] CPU 0 Unable to handle kernel paging request at virtual address 2fe36098, epc == 86dc3b1c, ra == 86dc3d04
[ 69.660000] Oops[#1]:
[ 69.660000] CPU: 0 PID: 2041 Comm: bw_set Not tainted 3.10.49 #3
[ 69.660000] task: 8782baa0 ti: 864c4000 task.ti: 864c4000
[ 69.660000] $ 0 : 00000000 7f848590 2fe36098 00000001
[ 69.660000] $ 4 : 864a9480 00000001 86499380 00013ffd
[ 69.660000] $ 8 : 00000001 00013ffc 86499700 00000000
[ 69.660000] $12 : 00000000 00000001 001f0041 00000000
[ 69.660000] $16 : 864a9100 86499580 864cc000 a996a098
[ 69.660000] $20 : 555bce80 00000000 555a7d00 5532d3e1
[ 69.660000] $24 : 00000002 801fc720
[ 69.660000] $28 : 864c4000 864c5e00 86dc0000 86dc3d04
[ 69.660000] Hi : 00000000
[ 69.660000] Lo : 000040be
[ 69.660000] epc : 86dc3b1c apply_to_every_string_map_value+0x1268/0x158c [ipt_bandwidth]
[ 69.660000] Not tainted
[ 69.660000] ra : 86dc3d04 apply_to_every_string_map_value+0x1450/0x158c [ipt_bandwidth]
[ 69.660000] Status: 1100dc03 KERNEL EXL IE
[ 69.660000] Cause : 80800008
[ 69.660000] BadVA : 2fe36098
[ 69.660000] PrId : 0001974c (MIPS 74Kc)
[ 69.660000] Modules linked in: ath9k ath9k_common qcserial pppoe ppp_async option iptable_nat ath9k_hw ath usb_wwan sierra qmi_wwan pptp pppox ppp_mppe ppp_generic nf_nat_pptp nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv4 nf_conntrack_amanda mac80211 ipt_MASQUERADE cfg80211 xt_time xt_tcpmss xt_string xt_statistic xt_state xt_recent xt_quota xt_pkttype xt_physdev xt_owner xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_iprange xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_addrtype xt_TCPMSS xt_REDIRECT xt_NETMAP xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY usbserial usbnet usblp ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm slhc nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_proto_gre nf_nat_irc nf_nat_h323 nf_nat_ftp nf_nat nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_proto_gre nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast nf_conntrack iptable_raw iptable_mangle iptable_filter ipt_REJECT ipt_ECN ip_tables ebt_among ebt_802_3 crc_ccitt compat cdc_wdm cdc_acm fuse em_nbyte sch_teql sch_htb sch_prio act_ipt em_meta sch_gred sch_dsmark cls_basic em_text act_police sch_codel sch_tbf sch_sfq em_cmp sch_red act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ledtrig_usbdev xt_set ip_set_list_set ip_set_hash_netport ip_set_hash_netiface ip_set_hash_net ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink xt_IMQ imq ipt_weburl ipt_webmon ipt_timerange ipt_bandwidth nfsd nfsv3 nfs msdos ip_gre gre ip_tunnel tun vfat fat lockd sunrpc hfsplus nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 sha1_generic ecb arc4 crypto_blkcipher usb_storage ohci_hcd ehci_platform ehci_hcd sd_mod scsi_mod gpio_button_hotplug ext4 crc16 jbd2 mbcache usbcore nls_base usb_common exportfs crypto_hash
[ 69.660000] Process bw_set (pid: 2041, threadinfo=864c4000, task=8782baa0, tls=777d0440)
[ 69.660000] Stack : 0000001d 868fb0d4 00000000 86e56828 00000003 00000000 00000003 0101baa0
00000000 62646973 74342d64 6f776e6c 6f61642d 6461792d 33310000 00000000
00000031 2f757372 2f646174 612f6277 6d6f6e2f 62006820 00000000 00000000
555aa3c0 00000002 00000004 00000000 00000000 5532d3e0 86dc4170 00000800
7f844590 86465600 00000000 00000000 00000000 00000000 7f93b110 801bf070
[ 69.660000] Call Trace:
[ 69.660000] [<86dc3b1c>] apply_to_every_string_map_value+0x1268/0x158c [ipt_bandwidth]
[ 69.660000] [<86dc3d04>] apply_to_every_string_map_value+0x1450/0x158c [ipt_bandwidth]
[ 69.660000]
[ 69.660000]
Code: 104000ac 02531021 93a3001c <10600098> 8c550000 8c430004 8e040000 afa30074 8c830064
[ 70.030000] ---[ end trace 06ac3a6ad8e0a4c1 ]---
[ 70.030000] Kernel panic - not syncing: Fatal exception in interrupt
[ 70.030000] Rebooting in 3 seconds..
Potresti provare ad aggiornare uboot magari il problema risiede in quello...
Comunque hai provato anche a caricarci su openwrt? (la trunk naturalmente)
ciao
mi farsti cosa gradita dirmi come fare per aggirnare uboot , e nel caso lincarmi il trunck
allora siccome uboot non penso io prima proverei a metterci openwrt trunk
Eccoti il link :D
https://downloads.openwrt.org/snapshots/trunk/ar71xx/generic/openwrt-ar71xx-generic-tl-wdr3600-v1-squashfs-factory.bin
Allora siccome č trunk manca luci (l'interfaccia web)
Per installarla ti devi collegare al router con winScp andare in /etc/config e modificare il file network se hai il modem in bridge e devi far fare la connessione pppoe al router, altrimenti non dovrebbe servire...
In tal caso basta aprire putty, collegarti a 192.168.1.1 utente root
fare opkg update e poi opkg install luci
Dimmi se non hai capito qualcosa
ciao
grazie per il linck
allora il trunck lo mando come recovery ----- giusto ?
poi non avendo il trunck una interfaccia web mi devo colegare con putty e dpopo che mi sono logato come utente root devo dare i due comandi
questo e quello che o capito
si corretto se hai problemi scrivi e risolviamo...
Sperando di risolvere
ciao
purtroppo non si e ancora risolto ,mandato il file ma va sempre in reboot ,,,,e in + sembra che non lo scriva neanche
foto con la fine del upload
(http://i.imgur.com/N24KzX4.png)
ma quando (dopo che si riavvia ) vedo che sta ancora gargoile 1.7.1
(http://i.imgur.com/0KRz24n.png)
grazie per altre info
ai provato di cambiare l`alimentatore?
ciao
no ,ma provo ,ne o due di scorta
aggiornamento
cambiato alimentatore con altro sempre da 12 volt ma da 1.5 amper ,ma sempre uguale
a me sembra che non lo scrive proprio... Dovresti fermare uboot e scriverlo da comando... ma non ricordo benissimo e se dai comando male brikki il modem... domani ti dico meglio che oggi non ho testa
ciao
in attesa
https://www.ilpuntotecnico.com/forum/index.php/topic,75624.msg206481.html#msg206481 segui questa guida, aggiorni uboot e poi usi l'interfaccia web per flashare l'immagine nuova
o scaricate i file domani prova ,,e scrivo i risultati
ciao
metto le foto cosi si capisce meglio
sembra che o fatto tutto alla lettera ma il problema persiste ,riavvio continuo
nb alla fine della guida ,scrivi GUIDA FINITA ,,e io o spento e riacceso il router sembra che non sia cambiato nulla
(http://i.imgur.com/Ue7Ejgj.png)
(http://i.imgur.com/Rp0wyrX.png)
(http://i.imgur.com/LYfZimB.png)
perchč ora hai uboot modificato
Quando lo accendi tieni premuto il tasto reset per 3-4 secondi e poi lascialo
Collegati al router e vedi se riesci a vedere una interfaccia web dove flashare il firmware
ciao
grazie per l'aiuto datomi ,recuperato
dopo aver tenuto premuto per circa 4 secondi il tasto reset sono entrato nella paggina per fare upgrade del firmware (che risultava corrotto )
fatto l'upgrade con gargoyle_1.9.0-ar71xx-generic-tl-wdr3600-v1-squashfs-factory.bin
e dopo il riavvio
(http://i.imgur.com/3prlHhD.png)
Perfetto :D
allora era come pensavamo noi si era corrotto il firmware e non lo flashava...
Un flash da uboot ha risolto tutto felice di averti aiutato (e di averti resto il boot pių veloce)
