  • 3527 Risposte
  • 1700360 Visite
Offline fiberman
  • 190
« Risposta #1755 il: 11 Dicembre 2020, 09:14 »
(che su alcuni dispositivi installava pezzi sul modoverlay e altri sull'overlay reale dato che in alcune casistiche veniva richiamato il mount di modoverlay a device avviato
questa cosa esattamente come la verifico, cosa devo cercare con winscp  ?
Offline putipower
  • 284
« Risposta #1756 il: 11 Dicembre 2020, 09:58 »
sono normali questi errori?
Root Script: Checking installation prerequisites, if needed installation will continue after reboot...
Root Script: Installing in progress...
Collected errors:
 * opkg_conf_parse_file: Duplicate src declaration (chaos_calmer_base https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/base). Skipping.
 * opkg_conf_parse_file: Duplicate src declaration (chaos_calmer_packages https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/packages). Skipping.
 * opkg_conf_parse_file: Duplicate src declaration (chaos_calmer_luci hhttps://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/luci). Skipping.
 * opkg_conf_parse_file: Duplicate src declaration (chaos_calmer_routing https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/routing). Skipping.
 * opkg_conf_parse_file: Duplicate src declaration (chaos_calmer_telephony https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/telephony). Skipping.
t Script Checking and force-enabling dropbear SSH Server for root on lan
Root Script Restarting Dropbear SSH Server...
Root Script OBP sanity check succeeded.
Root Script Force/install flag detected! Reinstalling...
Root Script Start rooting
Root Script Executing /etc/modgui_scripts/01_prereq.sh
Root Script Disabling watchdog...
Root Script Checking Free RAM...
Root Script Saving GUI package to /root...
Root Script Executing /etc/modgui_scripts/02_specific.sh
Root Script Checking opkg feeds...
Root Script Applying specific model fixes...
Package busybox_telnet (1.28.4-3) installed in root is up to date.
Package libopenssl (1.0.2s-1) installed in root is up to date.
Package openssl-util (1.0.2s-1) installed in root is up to date.
Root Script Executing /etc/modgui_scripts/03_various.sh
Root Script Fixing sysupgrade if needed...
Root Script Restoring and enabling few transformer mappers...
Root Script Transformer lib check
Root Script Creating custom GUI utils symlinks...
Root Script Add checkversion to cron...
Root Script Executing /etc/modgui_scripts/04_config.sh
Root Script Check original config
Root Script Unlocking web interface if needed
Root Script Check if variant_friendly_name set
Root Script Check Dropbear config file
Root Script Check eco paramaters
Root Script Add app-extension var in modgui uci config
Root Script Add new web options
Root Script New DHCPRelay Option
Root Script Suppressing wansensing logs
Root Script Create new option for led definitions
Root Script LedEventing new md5sum: ae62bfe6297c81c5c2024ec94b922c84
Root Script LedEventing md5sum: ae62bfe6297c81c5c2024ec94b922c84
Root Script Creating and checking real version
Root Script Implementing WoL
Root Script Apply new xDSL options
Root Script Adding fast cache options
Root Script Checking DoSprotect kernel modules...
Root Script Enabling and starting DoSprotect service...
Root Script Checking mobiled libs...
Root Script Checking if intercept is enabled and disabling if it is...
Root Script Disabling coredump reboot...
Root Script Restoring nginx additional options if needed...
Root Script Adding missing voicednd rule if needed
Root Script Doing various checks and generating hashes...
Root Script Update branch detected: DEV
Root Script Detected upgrade!
Root Script Old GUI hash: 0bae35a234d91ec4864706136fd30fbe
Root Script New GUI hash: 1d01b7624a35c453f930d6134dd3417e
Root Script Resetting version info...
Root Script Decrypting any encrypted password present in config
Root Script Executing /etc/modgui_scripts/05_app.sh
Root Script Trafficmon inizialization
Root Script Enable DLNAd
Root Script Move Aria2 dir
Root Script Reinstalling Telstra GUI if needed...
Root Script Executing /etc/modgui_scripts/06_network.sh
IspConfigHelper Detecting ISP and cleanup...
IspConfigHelper Checking detected ISP and setting CWMP...
IspConfigHelper TIM ISP detected, finding CWMP server...
IspConfigHelper CWMP Server detected: https://regman-mon.interbusiness.it:10800/acs/
IspConfigHelper Resetting unlock bit...
IspConfigHelper Restarting dnsmasq if needed...
Root Script Removing default loopback DNS Servers...
Root Script Purify WAN network config...
Root Script Fix DNS bug, make sure odhcp is enabled
Root Script Enabling odhcpd on boot
Root Script Checking and fixing dnsmasq daemon naming...
Root Script Sync DHCP configuration for new GUI
Root Script Attempt to clean the wansensing script from hardcoded interfaces...
Root Script Cleaning cups firewall rule...
Root Script Apply CVE 2019-11477 workaround
Root Script Checking atmdevice interface naming...
Root Script Restarting dnsmasq if needed...
Root Script Executing /etc/modgui_scripts/99_postreq.sh
Root Script Applying modifications
Root Script Resetting cwmp and watchdog
Root Script Removing .install_gui flag
Root Script Process done.
Root Script Restarting transformer
Chiudi
e' normale che vado per aggiornare alla .33 e mi ritrovo sempre la .31?
« Ultima modifica: 11 Dicembre 2020, 12:19 da MisterFTTH »
  • 3399
« Risposta #1757 il: 11 Dicembre 2020, 10:43 »
@fiberman teoricamente basta un df -h o comunque esplora in /overlay/bank_2 se hai la cartella /etc/config con dati dentro ad esempio
@putipower avrai delle righe duplicate in /etc/opkg.conf, son sicuro è la blacklist non installata da GUI che te le ha messe.
che sia normale che ti ritrovi sempre .31 ovviamente non è normale ma cosa lo causa a quanto pare ancora non è chiaro...anzi come non detto ora dovrebbe essere apposto
« Ultima modifica: 11 Dicembre 2020, 10:50 da FrancYescO »
Offline fiberman
  • 190
« Risposta #1758 il: 11 Dicembre 2020, 11:09 »
non ho nessuna cartella config in /overlay/bank_2/etc .
« Ultima modifica: 11 Dicembre 2020, 11:11 da fiberman »
  • 3399
« Risposta #1759 il: 11 Dicembre 2020, 11:22 »
apposto così.
Offline putipower
  • 284
« Risposta #1760 il: 11 Dicembre 2020, 12:08 »
@FrancYescO
ho ripulito e reinstallato tutto...ho aggiornato a 2.2.3-003 e ripristinato tutto a mano con ultima dev .34....funziona tutto...blacklist per il momento lho installato da shell,adblock funziona
ho solo questa anomalia
https://ibb.co/5hLzyWq ogni tanto mi compare  ma se premo su cerca aggiornamenti sparisce
secondo te ho un istallazione pulita?
https://ibb.co/Z1hyRmj
  • 3399
« Risposta #1761 il: 11 Dicembre 2020, 12:40 »
l'installazione mi pare essere ok, e ormai anche la blacklist non dovresti avere più problemi a tenere quella installata da gui (anche perchè credo se non la installi da li perdi la pagina per aggiungere i numeri da bloccare ad ogni update GUI).
quel firmware beta come al solito non ha senso che tu lo abbia, curioso tralaltro che abbia quei ultimi mount..
quel messaggio in alto, non dovrebbe essere li meno che ancora non lo hai riavviato postupgrade... probabilmente hai ripristinato un backup prima che lo riavviavi per far applicare OBP e ovviametne era un caso non gestito ... ti dovrebbe bastare un uci set modgui.var.reboot_reason_msg=""
« Ultima modifica: 11 Dicembre 2020, 13:10 da FrancYescO »
Offline putipower
  • 284
« Risposta #1762 il: 11 Dicembre 2020, 13:10 »
no non ho ripristinato backup
provero ad installare blacklist da gui
grazie per l'aiuto
Offline MisterNobody
« Risposta #1763 il: 11 Dicembre 2020, 14:43 »
È possibile inserire una vpn, con questa mod? Non trovo l'opzione da nessuna parte.
« Ultima modifica: 11 Dicembre 2020, 17:04 da MisterNobody »
  • 3399
« Risposta #1764 il: 11 Dicembre 2020, 14:44 »
vps?
Offline putipower
  • 284
« Risposta #1765 il: 11 Dicembre 2020, 15:18 »
grazie alert sparito
« Risposta #1766 il: 11 Dicembre 2020, 17:05 »
vps?
Vpn corretto. Ho trovato uno guida qui. Ma non so se è compatibile con le nuove versioni del firmware
Offline putipower
  • 284
« Risposta #1767 il: 11 Dicembre 2020, 19:13 »
con la dev 9.6.41 se imposto da funzioni extra di sistema modalita spoof imposta manualmente la versione etc ,quando provo a salvare da messaggio di errore
Offline bandit400
  • 102
« Risposta #1768 il: 11 Dicembre 2020, 20:31 »
DGA4132
AGTHP_2.1.0
9.6.41-7c5089c4
Confermo che restituisce errore in "Funzioni extra di sistema" -> "Impostazioni Spoof" quando si imposta:
 - "Modo versione spoof" -> "Imposta manualmente la versione da comunicare a CWMP"
 - "Versione impostata" -> <versione_desiderata>
« Risposta #1769 il: 11 Dicembre 2020, 20:52 »
Con le ultime modifiche della gui è inaccessibile sul 789Xtream, anche partendo da zero.
https://termbin.com/9xgy
EDIT
Errore mio non avevo resettato la bank_1
« Ultima modifica: 11 Dicembre 2020, 21:20 da larsen64it »
