joefull:
/etc/config/network
--- Codice: ---config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fddd:2913:eabf::/48'
option default_ps '0'
config interface 'lan'
option ifname 'eth0 eth1 eth2 eth3'
option type 'bridge'
option ip6assign '64'
option force_link '0'
option ip6class '6rd'
option ipv6 '1'
option ip6hint '0'
option ip6weight '1'
option stp '1'
list pppoerelay ''
option ipaddr '192.168.1.1'
config interface 'Guest'
option ipaddr '192.168.78.1'
option ifname 'wl0_2'
option ipv6 '1'
option ip6hint '1'
option ip6weight '0'
list pppoerelay ''
config switch 'bcmsw'
option reset '1'
option enable_vlan '0'
option qosimppauseenable '0'
option jumbo '0'
config interface 'sfp'
option ifname 'eth4'
option ipaddr '169.0.0.2'
config interface 'wan'
option proto 'pppoe'
option username 'utentepppoe'
option password 'passwordpppoe'
option reqopts '1 3 6 15 33 42 43 51 121 249 212'
option vendorid 'Technicolor_DGA4131FWB/dslforum.org'
option authfail '0'
option iface6rd '6rd'
option zone6rd 'wan'
option mtu '1500'
option initboot '1'
option ipv6 '0'
option notused 'A4:91:B1:B5:6F:D7'
option ifname '@vlan_wan'
option auto '1'
config interface 'mgmt'
config device 'vlan_eth4'
option type '8021q'
option ifname 'ptm0'
option mtu '1500'
option name 'vlan_eth4'
option vid '835'
config interface 'wantag'
option reqopts '1 3 6 15 33 42 51 121 249 212'
option authfail '0'
option mtu '1500'
option initboot '1'
option ipv6 '0'
option auto '1'
config interface 'wwan'
option auto '1'
option proto 'mobiled'
option session_id '0'
option profile '1'
config interface 'vlan_wan'
option ifname 'vlan_eth4'
config device 'if0atm'
option enable '1'
option name 'atm0'
option macaddr 'A4:91:B1:B5:6F:D6'
config device 'if1atm'
option enable '1'
option name 'atm1'
option macaddr 'A4:91:B1:B5:6F:D7'
config config 'config'
--- Termina codice ---
LuKePicci:
Eh si, come pensavo c'è un errore.
--- Codice: ---config device 'vlan_eth4'
option type '8021q'
option mtu '1500'
option vid '835'
Questo non è ne carne ne pesce. La configurazione funziona perchè il sistema del come tu abbia intenzione di chiamare questa interfaccia, wan_eth4 o pippo per lui è uguale, ma quei nomi sono stati creati seguendo una logica. vlan_eth4 significherebbe "questa interfaccia è una vlan (con vid 835) su porta eth4" ma tu gli hai tolto eth4 e messo ptm0. Fintanto che è comunque una porta valida per lui va bene e te la fa funzionare. Ma il software che gestisce le luci leggendo che la tua interfaccia su internet è vlan_eth4 va a controllare che ci sia una connessione internet sulla porta eth4, e non sul modem ptm0. Nelle configurazioni originali c'era sicuramente una vlan_ptm0 (su vid 100) che tu hai rimosso. Recuperala e cambiane il vid da 100 a 835, oppure rinomina vlan_eth4 in vlan_ptm0. Poi vai sotto vlan_wan e metti vlan_ptm0 al posto di vlan_eth4.
joefull:
ho modificato in questo modo ma nulla di fatto:
File ENV
config envvars 'custovar'
option wan_if 'wan'
option wan_tag '1'
File Network
option ifname 'lo'
option ula_prefix 'fd56:d2bc:a9cf::/48'
option ipaddr '192.168.1.254'
option ipv6 '1'
option ip6hint '0'
option stp '1'
list pppoerelay ''
option ipv6 '1'
option ip6hint '1'
list pppoerelay ''
option reset '1'
option jumbo '0'
option authfail '0'
option mtu '1500'
option initboot '1'
option ipv6 '0'
option auto '1'
config device 'vlan_ptm0'
option type '8021q'
option mtu '1500'
option name 'vlan_ptm0'
option vid '835'
option proto 'dhcp'
option authfail '0'
option mtu '1500'
option initboot '1'
option ipv6 '0'
option auto '1'
option auto '1'
option profile '1'
option ifname 'vlan_ptm0'
option enable '1'
option name 'atm0'
option enable '1'
option name 'atm1'
LuKePicci:
Scusami e perchè hai messo wan_tag=1 in env?
PS: va da se che devi fare il reload delle configurazioni dopo averle cambiate per vederne gli effetti
joefull:
messo wan_tag=0 sistemato(dopo diverse prove l'avevo dimenticato)
scusa il reload come lo devo eseguire?
Navigazione
[0] Indice dei post
Vai alla versione completa
