  • 6093499 Visite
Offline shdf
  • 981
« Risposta #6075 il: 22 Gennaio 2018, 22:21 »
Ecco come fare per avere il Firmware 1.1.0 Rooted, sorry tutto in inglese :wasntme:
Here is how to safely use the latest Firmware AGTEF_1.1.0_002_CLOSED.rbi (and test the latest DSL driver ;D).
1) from your actual firmware, with Winscp, delete both folders /overlay/bank_1 and /overlay/bank_2
2) with AutoFlashGui, flash the latest Firmware AGTEF_1.1.0_002_CLOSED.rbi (no need to try to root it)
3) once the new firmware is flashed and the modem finished to reboot, with AutoFlashGui downgrade to AGTEF_1.0.3_CLOSED.rbi
4) Now you have one Passive Bank with firmware 1.1.0_002 and one active bank with Firmware 1.0.3
5) So you are now on Firmware 1.0.3, do the Root process with AutoFlashGui.
6) With putty you can now check which is the inactive bank, the inactive bank is where the Firmware 1.1.0 is installed.
do a cat /proc/banktable/inactive
7) so let's say your inactive bank is bank_1, then we are going to edit some files in /overlay/bank_1/etc/ to enable the root.
8') in /overlay/bank_1/etc/passwd and /overlay/bank_1/etc/passwd- overwrite the first line with :
root:x:0:0:root:/root:/bin/ash
9) in /overlay/bank_1/etc/shadow and /overlay/bank_1/etc/shadow- overwrite the first line with what you have in /etc/shadow and /etc/shadow-
10) in /overlay/bank_1/etc/config/dropbear
config dropbear 'lan'
option IdleTimeout '600'
option PasswordAuth 'on'
option Port '22'
option Interface 'lan'
option RootPasswordAuth 'on'
option enable '1'
config dropbear 'wan'
option enable '0'
option Port '22'
option Interface 'wan'
11) ok, so now from putty you can do a switchover, this will switch you on the other bank and reboot the modem on firmware 1.1.0 Rooted
12) now you can configure your network in /etc/config/network
Offline LorenzoL
  • 417
« Risposta #6076 il: 22 Gennaio 2018, 23:32 »
Edit - credevo di essere riuscito a migliorare la lentezza cronica del wireless 2.4Ghz; purtroppo dopo alcune ore di ottimismo, la velocità è lentamente tornata alla triste lentezza abituale. Chiedo venia.  :facepalm:
« Ultima modifica: 23 Gennaio 2018, 01:28 da LorenzoL »
Offline Ivymike
  • 103
« Risposta #6077 il: 23 Gennaio 2018, 00:02 »
@LorenzoL visto che sembri saperne... come mai il comando "wl -a wl1 txpwr x" non funziona mentre col wl0 si?
Inoltre non si riesce a fare una programmazione per il wifi separata per le 2 bande come su netgear?
Adesso provo a vedere anche io sta storia del wifi 2,4GHz
@shdf buona cosa anche se preferisco aspettare dopo aver quasi bloccato tutto. Se hai provato a installarla, puoi estrarre il driver della 1.1.0?
« Ultima modifica: 23 Gennaio 2018, 00:04 da Ivymike »
Offline Ivymike
  • 103
« Risposta #6078 il: 23 Gennaio 2018, 00:14 »
Io al momento ho provato a mettere CPU a "1" e togliere "Attesa CPU", come wifi invece nella 2,4 ho tolto canale "AUTO" e ho impostato 1.
Al momento sono 15 minuti che ho 300Mbps.
Ma la GUI 4.6.8, è normale che mi dica "Versione Gold (17.1)"?
La 17.3 cos'è? e dov'è?
Offline LorenzoL
  • 417
« Risposta #6079 il: 23 Gennaio 2018, 00:25 »
Mi sopravvaluti, sono solo un praticone che si arrangia. wl0 è la sigla dell'interfaccia 2.4Ghz:
config wifi-iface 'wl0'
   option device 'radio_2G'
   option mode 'ap'
   option state '1'
   option network 'lan'
   option reliable_multicast '0'
   option uapsd '0'
   option ssid 'TIM-27799225'
wl1 è quella del 5Ghz che non è modificabile.
Io ho la vers. Cyan 17.3, che sarebbe la 1.1.0_002, ultima beta.
« Ultima modifica: 23 Gennaio 2018, 00:41 da LorenzoL »
Offline ^NiCo^
  • 1258
« Risposta #6080 il: 23 Gennaio 2018, 00:57 »
Come và l' ultima beta ? Ha problemi ? tipo pass che si resetta, sezioni non funzionanti come la 1.0.4 o altro ?
Offline shdf
  • 981
« Risposta #6081 il: 23 Gennaio 2018, 08:18 »
Non ho provato abbastanza ma per il momento non ho visto nessun problema...sono sempre sulla Gui TIM, la configurazione la faccio tutto a mano nei config files.
il driver dsl non mi ha cambiato nulla di visibile...aggancio sempre a 90Mbps
« Risposta #6082 il: 23 Gennaio 2018, 08:58 »
scusate ragazzi ,ma come si fa a postare un immagine della Gui modem nel post ?
Offline Ivymike
  • 103
« Risposta #6083 il: 23 Gennaio 2018, 09:10 »
   option mode 'ap'
   option state '1'
   option uapsd '0'
Si si lo so che wl0 è la 2,4 non capisco come mai non si riesce a modificare la wl1.
E se i comandi li si mette direttamente in rc.local... rimangono sempre, giusto?
Per la GUI quindi la Cyan si mette dalla 1.1.0? Pensavo che fosse indipendente dal firmware
« Risposta #6084 il: 23 Gennaio 2018, 10:44 »
Di base questo forum non consente di uploadare direttamente le immagini, pertanto devi utilizzare un servizio qualsiasi di image hosting ed inserire poi nel tuo intervento il link all'immagine fornito dal medesimo.
Se ti viene fornito anche un link diretto, del tipo http://example.com/image.jpg, per integrare l'immagine nel tuo post puoi utilizzare in alternativa il comando Inserisci immagine disponibile a menu:
Offline shdf
  • 981
« Risposta #6085 il: 23 Gennaio 2018, 12:02 »
Stasera vi Faccio un tutoriale su come sbloccare la GUI stock TIM sul Firmware 1.1.0.x  ;)
« Ultima modifica: 23 Gennaio 2018, 12:14 da shdf »
Offline LorenzoL
  • 417
« Risposta #6086 il: 23 Gennaio 2018, 12:53 »
@shdf - interessante, grazie; visto che sei molto competente, non riesci a trovare un rimedio per velocizzare il wifi 2.4, che è lentissimo? Merci bien.  :bye:
Offline Ivymike
  • 103
« Risposta #6087 il: 23 Gennaio 2018, 13:02 »
quindi sul 1.1.0 non si può mettere la GUI col solito metodo?
Offline enrico2772
  • 327
« Risposta #6088 il: 23 Gennaio 2018, 13:20 »
Ethernet EEE
Ethernet Ethapd
chi mi sa dire cosa significa ?? e vanno lasciati su on o su off???
grazie amici
Offline shdf
  • 981
« Risposta #6089 il: 23 Gennaio 2018, 13:28 »
Tutto sembra molto stabile e senza bug, Non ho niente maneggiato nella GUI, l'ho solo sbloccata. Non c'è tutto ciò che ha aggiunto Ansuel, ma ce n'è il principale.
Per sbloccare la GUI bisogna solo modificare il file /etc/config/web
« Ultima modifica: 23 Gennaio 2018, 13:37 da shdf »
