and it's the pppoe that goes in timeout not the dsl connection right?can you repost the /etc/config/network ?
config interface 'loopback' option ifname 'lo' option proto 'static' option ipaddr '127.0.0.1' option netmask '255.0.0.0'config globals 'globals' option ula_prefix 'none' option default_ps '0'config device 'waneth4' option type '8021q' option name 'waneth4' option macaddr '10:13:31:xx:xx:xx' option ifname 'eth4' option vid '835' option ipv6 '0'config device 'wanptm0' option name 'wanptm0' option macaddr '10:13:31:xx:xx:xx' option ipv6 '0'config interface 'wan' option macaddr '10:13:31:xx:xx:xx' option ifname 'ptm0'config config 'config' option wan_mode 'bridge'config interface 'wwan' option auto '1' option proto 'mobiled' option session_id '0' option profile '1' option enabled '0'config interface 'wan6' option proto 'dhcpv6' option reqopts '12 21 22 23 24 25 31 56 64 67 82 83' option noslaaconly '1' option iface_464xlat '0' option auto '0' option dns_metric '20' option ifname '@wan_ipv6' option enabled '0'config interface 'lan' option type 'bridge' option proto 'static' option ipaddr '192.168.1.1' option netmask '255.255.255.0' option ip6assign '64' option force_link '0' option ipv6 '0' option pppoerelay 'ptm0' list ifname 'eth0' list ifname 'eth1' list ifname 'eth2' list ifname 'eth3' list ifname 'eth5' list ifname 'ptm0'config switch 'bcmsw' option reset '1' option enable_vlan '0' option qosimppauseenable '0' option jumbo '0'config interface 'wlnet_b_24' option proto 'static' option ip6assign '64' option ipv6 '0' option ip6hint '1' option netmask '255.255.255.128' option ipaddr '192.168.168.1' option ifname 'wl0_1' option force_link '0' option name 'Ospiti-TIM-24068835'config interface 'wlnet_b_5' option proto 'static' option ip6assign '64' option ipv6 '0' option ip6hint '2' option netmask '255.255.255.128' option ipaddr '192.168.168.129' option ifname 'wl1_1' option force_link '0' option name 'Ospiti-TIM-24068835'config device 'wlnet_b_5eth5' option type '8021q' option name 'wl1_1' option enabled '1' option ifname 'eth5' option vid '3' option ipv6 '0'config interface 'ipoe' option proto 'dhcp' option metric '1' option reqopts '1 3 6 43 51 58 59' option release '1' option neighreachabletime '1200000' option neighgcstaletime '2400' option ipv6 '1'bRead more at https://www.ilpuntotecnico.com/forum/index.php/topic,77325.5100.html#FDJq9r5zAWMem1kO.99
Dec 14 22:27:26 daemon.warn odhcpd[2428] sending DHCPV4_MSG_ACK to 12:13:31:xx:xx:xx - 192.168.254.101 Dec 14 22:27:26 daemon.warn odhcpd[2428] received DHCPV4_MSG_REQUEST from 12:13:31:xx:xx:x
192.168.254.101 ModemTIM-AP-715810
